Never heard of SwiftCarb - Extreme Endmills and Carbide Cutting Tools
Will check them out.
Evo Valve Cover | Frontline Fabrication
You guys are in denial.
Again, these are not my parts, but feel free to go look at images of the work done here: https://www.facebook.com/pages/Front...08500182556134
He cares about surface finish, and uses the best tools and equipment he can in order to get great results directly off the machine.
Here is a quote from the Swiftcarb catalog, "if you're not getting a mirror finish at 300+IPM, then you need to be using Swiftcarb". This is 2014, leverage technology. Again, a Tormach isn't going to do this, but don't tell us you can't.
PM-45 CNC conversion built/run/sold.
That someone posted pictures of surface finish from a tormach and a mori and said they were the "same", implying that a tormach or any R8 taper 1000lb machine can create surface finish quality at the same level as a VMC. Thats all.
I get high gloss finishes too, but those parts come out of the powder coating booth.
I used to hand polish and buff aluminum parts to a mirror finish. It is work. No doubt about it. I can see why one would want a machine that can produce the type of finish on the recent parts in this thread. High quality parts with less or no hand finishing. That statistic right there means more profit per part. When I did hand polish those parts, they would not stay looking that way even though a wax was applied. Same thing goes for these high machine finishes I would guess. They will never look better than when they come off the machine. Probably quite a bit different when they come out of a box a year or two later unless vacuum packed.
Lee
Swiftcarb makes really good end mills, but there is absolutely no way you're going to get that kind of finish off a milling machine. I don't care if you do it on a Tormach, Mitsui Sieki, Kitimura, Mazak, Mori Seiki, Fadal or a Haas, and I have run them all. And I have used a lot of Swiftcarb end mills too, and actually they're no better than any of other high performance end mills.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
Jid2 - reread the post guy, I never said they were the same finish. From my testing I know it's impossible to pull the same finish on this machine. All I was showing was from a part made on a Mori at 7x magnification the Tormach wasn't far behind after the mods. Before the mods the finish was horrible, didn't matter what settings, end mill, coolant, etc.. used, always looked the same/very little difference. I wasn't trying to write a novel explaining every little detail, saw someone asking about the mods and thought I'd chime in and show how they worked for us.
Hirudin - I don't know what the setting were for the Mori part, but after about 80 test cuts using just about every end mill I could find, tuning the machine and whatever the hell else I did 2 years ago that was my best set. I used a .5" ZRN Accupro 2FL EM OAL length I believe was 1" or 1.25". When testing everything trying to finish at Max RPMs still looked bad, but at about 2000 - 3000 rpm 20 - 35 IPM with a finishing pass of .001" -.002" WOC seemed to work great. It's all about what works for you.
Thank you Mike !
Your welcome sir!
mike sr
I just reread this thread and didnt find a pic of the belt adjustment setup, just in case someone is interested, the motor is also mounted on .0625/.125 silicone gasket material to isolate the motor from the machine frame, this helps a bit with vibration.
mike sr
