Any reason you don't want to adjust the thrust bearings to minimize the backlash?
Dave
I have tried all the admin commands for setting backlash to no avail!
I want to set Y backlash to .002 as backlash is approx .0028 now, I would like to know the proper syntax to enter this. In older versions there were commands to enter each individual axis backlash, I dont see these commands on version 2.8.3 which is what I am using now.
any help appreciated
thanks
mike sr
Dave
It is just an access problem, I cant get to them without moving a shelf assembly or moving the machine out of position, either is a major hassle.
I realize that this isnt the way to fix the problem correctly though. I did run a couple parts and the anomaly improved with backlash added and I at least know where the problem is.
I did figure out the syntax to get the backlash set.
mike sr
if you know how to modify your .ini file.
just need to add BACKLASH = 0.002 in the Y Axis section.
