OK I did a short survey about what guys wanted to see when they start a new program run.
Tools used List with all descriptions from the tool table to compare to the CAM side
Where tool changes occur in the program (line number)
Comments and notes in the Gcode with line numbers
AND they wanted it in 1 file to view or print out.
SO here it is. You load the Gcode program then press Ctrl_F10 and it creates a ProgramNotes.txt file. It show the tools and descriptions from the tool table, It shows the Tool change location in the Gcode (Line Number) It also show all Comments in the Gcode program AND the line number they are on.
IF you guys can think of anything else it needs please let me know.
(;-) TP
