- Reading HAL pins from the Gcode side
For anyone interested there is a way to read HAL pins from the Gcode side. Tormach did not strip this function out YET (;-) So for now it does work.
#5506 = #<_hal[hm2_7i80.0.encoder.00.velocity]>
Brings in the hal pin value for the spindle encoder to check IF the spindle has stopped rotating
I have not figured out a way yet to read #params from the Pythion side. IF self.params() actually worked in general it would be great.
(;-) TP
- You may not post replies
- You may not edit your posts
Forum Rules
