Tormach PathPilot WISH LIST (;-) - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 65 of 65
Thread: Tormach PathPilot WISH LIST (;-)
  1. #61
    Member kstrauss's Avatar
    Apr 2013
    Default Re: Tormach PathPilot WISH LIST (;-)
    The ISO graphic nicely shows gross problems but it would be really nice to have a numerical display of the maximum Z-axis depth of each tool at the beginning of a run.
  2. #62
    Member vmax549's Avatar
    Oct 2005
    Lady Lake
    HI Ken, that is an interesting thought. What would you expect to learn from knowing that ??? PP has a view function that appears to only display the current tool toolpathing would that help ?? I am not sure it actually does that (;-) though.
    (;-) TP
  3. #63
    Apr 2013
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    I might avoid a collision between my vise jaws and a tool! For example, I mostly do one-offs and frequently hold stock with Talon Grips. Typically I cut to within 0.01 or so of the grips. Due to senior moments I sometimes err. It is impossible to see the difference between 0.275 deep and 0.285 deep just by looking at the ISO view but a quick check of the numbers by tool would make such mistakes obvious. There is currently a display of toolpath extents but without tool numbers there is no way to know whether a deep cut is a drill in the centre of the stock or a clearing tool that will collide with the vise jaws.
  4. #64
    Oct 2005
    Lady Lake
    OK I see where you are going with that. It really would not be that hard to parse the Gcode from Tool to tool and retrieve the lowest Z value then post it on the screen Just below where it displays the tool length. Then when the tool number changes so does the Z extents for that tool. Good idea (;-)
    Have you ever tried to view the toolpath using the current tool only ?? I wonder if the extents change in the display ??
    (;-) TP
  5. #65
    Oct 2005
    Lady Lake
    I think that function is busted (;-) It sure works ODD.
    (;-) TP
