Hello, I am an overall machining noob, but I am trying to machine this drawer bay. I have the x & y coordinates set to 0,0 for the back lefthand corner, but the Z coordinate has given me several issues. I am trying to set the WCS to the top of the board as well at (18mm,) but PathPilot is stating that the machine would move approximately 10mm out of the machining area. I don't know if the heights I have set for my functions have any correlation, but the Clearance Height in Fusion for my functions is set to 10mm above the board which is the same as the displaying error. If anyone has any advice that would be greatly appreciated. Thanks!
I am using a Tormach 24r. I have tried multiple way to set my G54 to the top of the stock in the PathPilot software, but it always displays that the machine would surpass the Z threshold. (The stock is 3/4in thick)
The error you get is telling you that the move in Z will violate the softlimits in the Z+ direction (up) . Does the machine have home switches ?? Did you home the machine in Z? if so then you have a gcode problem. The CAM is posting moves that the machine cannot make.
(;-) TP
I believe its as his machine setup, his z-axis is in home(light on button is on) G54 is set at zero in this position and his tool length is zero according to the pic.
That light can be ON without it being homed correctly (;-) You can bypass the Switches(uncheck the limit switches) and home in place and THAT will throw everything out the window as far as machine positions. IF he has set the Zzero(G54) to the Home position so that machine Z zero and work Z zero are the same it will never work out as you would not be able to raise the spindle any higher. It will trip the Softlimit for Z.
The machine has to be homed to the switch and THEN you move down to the top of teh material to set G54 Work Zero for Z. IF that is the method you have choosen to use. THEN you look at the Gcode and see how far UP the Gcode is going to move you and that value HAS to be less than the distance of the softlimit value for Z+. Simple move the spindle UP to the Gcode value and see if it goes all the way up to that value without tripping the softlimit. IF it does you are good to go IF not then you have a Gcode problem.
(;-) TP
As a noob I doubt that he has disabled his home switches. It is more likely that he hasn't set Z-zero to the top of his stock (or where his CAM thinks it is). Also, having a tool length of zero probably means that he hasn't correctly setup his tool offsets.
You would be surprised at what all things a noobie will push and jiggle and wiggle trying to get the machine to work. (;-)
(;-) TP
Perhaps! My usual assumption is that things didn't work and he is asking why. Looking at his screen snapshot having the machine homed *AND* all axis at zero and the tool length also zero is suspicious.
Actually that looks normal (;-) IF you homed Z switched to G54 then moved down to the top of material and Set Z zero THAT is what it would look like. TO see how far offset you are go to the Offsets page and look at the G54 work offset value.
Just a thought, (;-) TP
Agreed that it looks normal (other than the tool length).
However, if z-zero is at the top of his stock then Z-limit exceeded would not be expected assuming good gcode.
It would also be the state if he homed his axis and then zeroed them. The expected error would be Z-limit exceeded for that situation.
I hope that ColbyGore posts again so that we can stop guessing.
In the G54 set the Z to ( 0 ) then bring the tool number say it is tool T1 to the top of your work and set tool Offset. So G54 will be set for your Part X----- Y------ Position, the Z will be set at Z0.0
In your program if you have done it correctly the tool will come down to cut the part this will be a Z- move so look in your program for the Z moves, if you don't see a Z- move then you have it setup incorrectly in you 360 Program
Post your program, just paste it in a reply
Mactec54
