What version of Lathe are you setting up 15L, 8L or other ?? I am finishing up with a 8L version install. In 8L there is an input pin where you bring in an encoder signal to drive the running RPM value. ALSO in 8L if that signal is missing the spindle will not start (safety function).
(;-) TP
