Click on the right side of the screen (there is a small pane of dots that is very hard to see), hold the mouse button down and drag the preview pane to the left to make it visible
Anyone know why I am minus the edit window (2.8.1)? I wonder if it could be the computer? We do use HF on the welder at times. I rebooted and re-downloaded and installed the update again to no avail. PP runs OK though, I just cant edit the post processor files.
My other computer that I test PP on has the window with the same update (2.8.1) and it works fine.
The reason I noticed it was that I was trying to edit a tapping macro to remove the G4 P2. delay, this is the one when it finishes tapping a hole it returns to Z clearance height then waits 2 seconds before moving to the next hole.
mike sr
The vertical resizers also toggle snap to common positions if you click them.
