- Need to change in Pathpilot STEP PER INCHES for axis XYZ
where is the INI file in order to change the STEPS PER INCHES for every axis XYZ.
I want to tweak it sigly in order to measure the accuracy gain.
I always make this test to my custom made CNC routers to increase the machine positioning precision.
You can check a video here: https://photos.app.goo.gl/ESgZdMXcHT8r6Cvx7
Re: Need to change in Pathpilot STEP PER INCHES for axis XYZ
~/tmc/configs/tormach_mill/
It will also depend on what model 1100 you have setup as to the exact file.
(;-) TP
- You may not post replies
- You may not edit your posts
Forum Rules
