Need Help! Thread milling - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: Thread milling
  1. #21
    Member kstrauss's Avatar
    Apr 2013
    Default Re: Thread milling
    TurboStep, have you found an affordable source of single pitch (multi-tooth) thread mills?
  2. #22
    Apr 2012
    I just today tested an M5x0.8 thread mill from Aliexpress. No big deal doing the Conversational, worked great in the delrin I am learning on. Used the Drill tab to locate the holes, milled the holes using a 2mm end mill (no 4.2mm stub drills yet), then the thread milling.
    https://huhaocnctool.aliexpress.com/store/3362033 was the store I bought from. Bought 2 of M3, M4, and M6. I used the M4 one todo the M5 threading.
    Aluminum next, then steel. Going down the list of skills to practice.
    Gerrit
  3. #23
    Dec 2008
    Switzerland
    Quote Originally Posted by kstrauss View Post
    In my language "affordable thread mills" is a contradiction in terms The most economical I've found so far are from Lakeshore or Maritool. The smaller ones in my photos are Swiss made (DIXI 1730) and cost $80 upwards.
    Quote Originally Posted by gerritv View Post
    That sounds a little strange...
    I checked out the link you provided but I couldn't find any metric thread mills. Do you have a part number?
    Step
  4. #24
    May 2013
    United Kingdom
    I found these but the postage to the UK £35 https://www.aliexpress.com/item/1005...72474f078OgkRv
  5. #25
    Apr 2013
    That is strange. It shows shipping to Canada is us$2.61. Did you perhaps choose to use DHL or EMS?
  6. #26
    Jun 2018
    on my feet
    onlinecarbide.com
    these guys have reasonable prices on thread mills . I've been eyeing them but haven't given them a try yet
  7. #27
    Member Tigster's Avatar
    Aug 2020
    Great info here guys, maybe I'll jump on board this weekend.
    I use Rouge endmills and own a thread mill but haven't used it yet. They are USA made (I think Utah) and great prices if you want something from The USA. They are a small shop with some killer equipment..look for their shop walk through on YouTube.
    https://www.carbidetoolsource.com/
  8. #28
    Dec 2008
    Switzerland
    Quote Originally Posted by Clive S View Post
    Starting from your link I finally arrived at what I was looking for:
    https://www.aliexpress.com/item/4001...33a04bcf3lQ8PG
    The G121007 appears to be suitable for M5 threads.
    @Gerrit: Is this what you used?
    Trying to look closely at the thread form they would appear to be ground to a point, but it's difficult to see, and the images might not reflect the actual part. If so, they will do the job, but the nominal diameter of the programmed thread may need to be adjusted slightly to compensate.
    I just ordered one so I'll find out in a month or two
    @Clive: Shipping to Switzerland was around $2.30 but the cheapest option for shipping to the UK was indeed £35!!! Is that perhaps due to the Brexit? If they work out and you're still interested we could possibly arrange something.
    Step
  9. #29
    Apr 2012
    I bought the L126010 (https://www.aliexpress.com/item/1005001298358910.html). I couldn't get my head around using the multi toothed ones.
    Attached some photos. The profile photo is at 20x. I'll be brave today and do some threads in aluminum/aluminium and then section it. I can go to 100x on my optical comparator.
    The tips are definitely not pointed, there is a flat at the tip although with 73 year old eyes they do look pointed.
    I will admit that when I ordered these I didn't look closely at the L, G et al variants. Most of my work will be in 6061 so the L series seemed a good enough fit. This is just a hobby for me so that often colours my choices, not into production or speed.
    Gerrit
    Attached Thumbnails Attached Thumbnails Thread milling-20210123_075523-custom-jpg   Thread milling-20210121_210249-custom-jpg   Thread milling-20210123_075720-custom-jpg
  10. #30
    Apr 2013
    Gerrit, I'm interested in your comparator. Is it from a published design or something that you created? Can you provide any further details?
  11. #31
    Apr 2012
    It is a Nippon Kogaku (Nikon) 6, a Kijiji find last year for CA$250. It came with 10, 20 and 100x lenses. Welded up a mobile stand, at chair height for comfo operation.
    Derek recently got a Jones & Lamson, similar size. They pop up fairly often. Shipping LTL from anywhere in Canada is quite reasonable.
    Gerrit
    Attached Thumbnails Attached Thumbnails Thread milling-20201101_162757-custom-jpg
  12. #32
    Mar 2010
    UK
    Am I right in thinking that threadmills have a recommended diameter range that they should be used for. I imagine the clearance angles on these cutters are designed to cut threads little bigger than the cutter. Anyone thread cut internal and external threads which are of large dia. Lets say cut a 50mm dia thread x 1.5mm pitch in alloy. using a 10mm threadmill? I am curious as to the finish that can be achieved? I find this thread very interesting (pun intended!) and wish to gather as much info on this procedure before buying and trying.
    I did look on aliexpress web site and most had ridiculous postage costs to the UK but after looking further they are available at reasonable shipping.
  13. #33
    Nov 2012
    Yes! For two reasons!
    The first is that the mill won't fit into the clearance hole of a too-small thread.
    The second is that the mill won't cut deep-enough threads of a too-large thread.
    That being said, the range is pretty big. I think I have a .100, a .180, and a .250 and they cut anything from M3 to M12 (and similarly sized imperials.) Might go even higher than M12 but I haven't needed it to.
    For M2.5, I use a Sandvik three-tooth that can really only cut that size/pitch, but it's great. That size is a little too small to screw around with micro mills.
    You're also right that the trapezoidal shape of the teeth is slightly more acute than the thread form 60 degrees, because it "spins through" an arc of the thread wall. If you're making super-tolerance space-science stuff, you might want a mill cut specifically for the particular thread you're making, but for regular 6H/6G tolerance, seems to work for me!
    You can cut that with a much smaller thread mill, the pitch is really what determines size tool you need. (That, plus stiffness.) The shape of the thread will be "better" the smaller the tool is, in general, as the overlapping arc between the thread and the tool is narrower. But you can take fewer passes, and feed faster, with a stiffer tool, so ... experiment!
  14. #34
    Apr 2012
    Speaking of Sandvik, here is their treatise on threading, for lathe and mill: https://tibp.blob.core.windows.net/c...48e5b7777a.pdf
    Their books provide stellar educational material.
    I will try to get the tip specifics from Huhao, they say to ask them for that if you need it. That would help determine the range of pitches and threads per cutter. My cutters are single tip.
  15. #35
    Member vmax549's Avatar
    Oct 2005
    Lady Lake
    In a Pinch you can always grind down a tap to a single point mill.
    (;-) TP
  16. #36
    May 2013
    United Kingdom
    Step
    @Step:
    It might be a mistake in the listings as there are other types there that are only about £2.50 postage.
    Thanks for the offer.
    Clive
Thread milling
Thread milling
