PathPilot Hub
Results 1 to 7 of 7
Thread: PathPilot Hub
    Member popspipes's Avatar
    Jun 2014
    Default PathPilot Hub
    I am trying out the HUB in PP and I havent figured out how to get one of my files uploaded to it.
    I do not use Fusion 360, I use sprutcam and I would like to upload one of my files to the hub to check out what it does and how it works etc., I cant figure out how to upload a file to it from my windows computer that I use for cad/cam.
    any help or insight would be appreciated!
    thanks
    mike sr
    Member kstrauss's Avatar
    Apr 2013
    Default Re: PathPilot Hub
    Login at https://hub.pathpilot.com/login?next=%2F
    Click on "Create Virtual Pathpilot Controller"
    Browse for a file and press "Upload"
    Click on "Enter Pathpilot"
    Choose your machine
    When the PP screen appears click on "File" tab
    If you do not see your file click on "Refresh" (the circular arrow thingey)
    Highlight the file and click on "Copy"
    Load your gcode as usual.
    You can go back to the original browser window and upload additional files. Remember to press "Refresh" after each upload.
    Jun 2014
    Quote Originally Posted by kstrauss View Post
    Choose your machine
    Thank you sir!
    I did finally figure it out, i cant get the file to run yet though, exceeds the Xaxis limit, I need to figure out how to set center of the part without using the probe, other than that I think it will run OK.
    mike sr
    Apr 2013
    Home PP and set the X/Y/Z coordinates to an appropriate location using the coordinate display/input boxes. It is just like a real machine!
    Jun 2014
    I did set the coordinates but not close enough I guess, the part is as long as the table almost, the fixture is marked off for the vise so I am close enough, then probe to get my zeros. I just didnt have much time to devote to it today (65*f) spent most of the day grinding up leaves and burning sticks.
    mike sr
    Apr 2013
    You can enlarge the work area slightly with the ADMIN SET_X_LIMIT and ADMIN SET_Y_LIMIT commands.
  7. #7
    Jun 2014
    Thanks, I hadnt thought of that. The part is actual length 16.6" long, so over 17 actual travel with a .25 cutter, My table travel is over 19" actual travel so that may be why I was having trouble setting the X zero.
    mike sr
PathPilot Hub
PathPilot Hub
