PathPiloto update to 2.6.0
Results 1 to 3 of 3
Thread: PathPiloto update to 2.6.0
    Oct 2005
    Default PathPiloto update to 2.6.0
    I ran into an interesting problem whjile updating from 2.3.6 to 2.6.0 . PathPilot will ONLY load up in demo mode. This is not a tormach machine and each time you update you have to go into the ini and hal files and update the info needed for it to run PathPilot . Otherwise you get the error screen and the option to reset pathpilot. BUT not this time around. I t always loads Demo mode. IT never shows the error screen at all and no option to reset PathPilot to a new config.
    Has Tormach made PathPilot to ONLY be useable by a true Tormach Machine ???
    (;-) TP
    Oct 2005
    Default Re: PathPiloto update to 2.6.0
    NOW THAT WAS REALLY ODD. When I updated PathPilot and the PC rebooted it lost the ethernet port. (;-( I guess it is time for some new parts .
    (;-) TP
    Feb 2009
    I run pathpilot 2.6.0 on a machine that is not a Tormach .
    Cant remember if it was 2.5 or 2.6 i did run into trouble where i could not get pathpilot to run.
    So i just did a quick back up . reinstall PP 2.0 then got it upgraded to 2.6 . No issues since
