- G96 (constant surface speed) for millturning?
Ive been playing with mill turning lately and have been having some good success, albeit on small brass parts for now. I see on the tormach website that pathpilot supports G96 for constant surface speed mode on the spindle but my post processor in Fusion doesn't output the appropriate codes to make it work. Digging through the config file it's not even mentioned. The post for the slant mill does contain references to G96-G97 but the two posts are so different I'm not sure I can smash the appropriate sections together to get it to work. Has anyone played with the mill post enough to get G96 to work? If so would you be willing to share your post?
- You may not post replies
- You may not edit your posts
Forum Rules
