PP 2.5.2
Results 1 to 1 of 1
Thread: PP 2.5.2
    Member kstrauss's Avatar
    Apr 2013
    Default PP 2.5.2
    Fixed Issues in this version:
    All
    • Typing ADMIN in the MDI Line DRO field displays a list of possible commands. We fixed an issue where using a mouse to click one of those commands could also click an item behind the list (like buttons in the Persistent Controls section, or lines of code in the G-Code window).
    Mills
    • We fixed issues where:
    o The 4th axis appeared to stall when it ran a G93 line, because it incorrectly interpreted the F word as the number of minutes(rather than 1/[number of minutes]).
    o The feed rate was too large with G93 and some G1 moves (with large A-axis motion and very small X,Y, or Z motion).
    o Improvements in PathPilot v2.5.1 to G43 unintentionally made some actions on the ATC tab unreliable.
    Lathe
    • In some situations, the set startline feature failed to run with programs that used G33/G76 threading cycles. This has been fixed.
    • We removed the tool path's green Refresh button, because the tool path now automatically refreshes.
    • You can now use the 100% Override buttons (for feed rate, spindle rpm, and maximum velocity) during G-code execution.
    Apr 2012
    Default Re: PP 2.5.2
    I was pleasantly surprised at how smoothly I updated from 2.0 to this in one go. A lot of improvements since 2.0 came out.
PP 2.5.2
PP 2.5.2
