PP din socket for tool setter
Results 1 to 5 of 5
Thread: PP din socket for tool setter
    May 2013
    United Kingdom
    Default PP din socket for tool setter
    PP din socket for tool setter.
    I have a tool setter non Tormach but looks the same mine does not have a led only to switches one for the tool trip and the other NC for the over travel fault.
    I am looking for the connections to this DIN socket for the two switches. I believe pin 1 is 5v dc - pin 4 is common - pin 2 not used - pin5 input - pin 3 is 12v dc
    May 2015
    Default Re: PP din socket for tool setter
    This is the schematic for the 1100m
    PP din socket for tool setter-5-pin-schematic-png
    PP din socket for tool setter-5-pin-jpg
    Attached Thumbnails Attached Thumbnails PP din socket for tool setter-5-pin-schematic-png   PP din socket for tool setter-5-pin-jpg
    May 2013
    United Kingdom
    Thanks for the info. My machine only has one Din socket. I would have thought that the Tormach setter would have a safety second switch in case the first one fails for some reason
    The same socket is used for different probes
    So I am looking for the correct pins on the din socket to put the switch across
    Sep 2017
    Quote Originally Posted by Clive S View Post
    Millfast Products advertises adapters that allows two devices to be installed. Depending on the model, they have one for 2 NO switches and a NO/NC version.
    May 2013
    United Kingdom
    With further investigation the pins to use are pin 4 and pin 5 looking at the front I have use NC contacts. So this is now solved thanks to all for the feedback.
