- ui_hooks -- a way to insert Python without it getting wiped out
Poking around in the latest PathPilot, it seems we actually have an import that does not get blown away during an upgrade.
The module "ui_hooks" in the gcode/python directory gets imported by the tormach_mill_ui.py module.
Some optional functions get called in that module, if they exist:
ui_hooks() -- takes the command, error_handler, version_list, and digital_output_offset parameters, and should return an object with callback methods.
stop_button(), reset_button(), estop_event() -- called when those buttons are pushed in the UI, if they exist on the ui_hooks object returned above.
Any single pendant manufacturer may be able to do everything they need with this one hook!
However, multiple hooks will clash -- there can be only one.
Still, this is major improvement!
- You may not post replies
- You may not edit your posts
Forum Rules
