That version of PathPilot is over 2 years old as well as the very first release of v2. I think you'll be happier with something more recent that has bugs fixed and new features. A PathPilot update only takes a few minutes to download and install. I suspect your Millfast goodies will still work. Most of the USB interface gizmos emulate the PathPilot keyboard shortcuts Esc for stop, Alt-R for cycle-start, space bar for feedhold, etc.
FWIW, there's a terse release note about a RapidTurn issue fixed in v2.0.1. Install the most recent version (v2.4.3 at the moment) and see what happens. V2.0.0 should have the ADMIN SETTINGS BACKUP MDI command. Copy the .zip file it creates to a USB stick before the update in case something bad happens. That .zip file will have the tool table and machine settings in it. You're on your own to backup any G code or other files on the controller to a USB stick.
Release Notes for PathPilot® v2.0.1
Release Date: January 9, 2018
Fixed Issues
All Machines
Some files are not correctly recognized as G-code, and the File tab will not load them. (PP-1887)
Mills
Resolved a RapidTurn® pausing issue when using G-codes dependent on spindle speed sensing.
Lathe
Resolved a rare G96 arc blend following error.
