Found it on page 3 of the PDF notes. It came out with 2.4.0
https://www.tormach.com/support/soft...release-notes/
I wish it had a way to "adjust" it. Say you are on part 34 and it messes up. Your only option is to reset it.
In the newest version of PP (2.4.2) when running the lathe, I now have some details over in the right window showing M30 A:xxxx B:xxxx. Appears that every time the program finishes it adds to the counter.
How do I rest this or change the numbers for A & B. It has the same thing for M99 A & B.
Thanks,
Awall
CoolCNCStuff.com
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
The documentation goes on to say:
It seems that, with G10, you can set it to whatever you want.To change a counter value explicitly, use a G10 command: G10 L99 P~ Q~
l P~ selects the cycle counter to change. Use any of the values detailed in the following table.
Cycle Counter P~
M30 A 0
M30 B 1
M99 A 2
M99 B 3
l Q~ specifies the value to set the cycle counter. If Q~ is omitted, the cycle counter is incremented by 1.
For example, if you program G10 L99 P2, the M99 A cycle counter increments by 1
I was reading that they increased the rapids speed for lathe with this upgrade.
I noticed the rapids on the 24r also changed or are displaying a different value anyway. Now it goes over 260 and before it was little over 200 . This was not detailed in release notes so I don't know if it was intended or not.
