Need Help! Finding the ini file to edit soft limits (tormach 770 S3)
Results 1 to 8 of 8
Thread: Finding the ini file to edit soft limits (tormach 770 S3)
    Mar 2016
    United Kingdom
    Default Finding the ini file to edit soft limits (tormach 770 S3)
    Been a while since I used the machine (hobbyist) and I can't remember how to get to the ini file to edit the machine's soft limits. The job I have JUST needs a few more mm in X travel to prevent re setting-up for another op.
    I've looked for this info here and in the manual but so far it escapes me! Any info / steps to help get me there will be much appreciated. Pathpilot is v.2.4.1.
    Cheers, Andy
    UK
    Member popspipes's Avatar
    Jun 2014
    Default Re: Finding the ini file to edit soft limits (tormach 770 S3)
    type "admin" in the MDI line hit enter, this brings up all the admin commands, X and Y travel are listed there.
    mike sr
    Mar 2016
    United Kingdom
    Quote Originally Posted by popspipes View Post
    Thanks, Mike for the quick response. I tried that (Something like ADMIN VIEW SOFT LIMITS / ADMIN SET X LIMIT XXX) but didn't get far in changing them, despite re-starting the controller afterwards. After some research it seems I have to edit the soft limits line in the machine's ini (initialization) file. Once done, they stay in place until the next software update. I just can't find a way to get to the ini file in the controller's file system. it's not a folder which can be viewed from the pathpilot 'file' tab. I think there's some combo button holds to press while starting-up, or while in PP, just can't find out how!
    If you know the soft limits can be changed from the MDI line, apologies, I obviously haven't found the right sequence of actions to get it done!
    Cheers, Andy
    Jun 2014
    Quote Originally Posted by Fortune7 View Post
    Cheers, Andy
    to get to the .ini files type ctrl+alt+x, then type caja in the terminal, then desktop will be available or the various folders are visible. The newer pp releases I had to modify the mill base.ini file, that file modifys the main .ini file on bootup. I dont remember the exact syntax for it.
    I did modify the soft limits in the mill base.ini files to reflect my changed settings, this worked for me.
    My limits are 10.125 in Y and 19.375 in X, factory is 9 x 18, I have a file that needs the full X axis setting.
    mike sr
    Jun 2014
    the syntax is ctrl alt x, then type caja in the terminal, all folders will be visible the files to modify are in "tormach_mill_base.ini".
    mike sr
    Mar 2016
    United Kingdom
    Mike,
    Many thanks - that got me there! My mill's a 770 S3, so the tormach_mill_base.ini file is for the 1100. The 770 gets its info from tormach_770_specific.ini, which I edited and got some extra X travel.
    Your response much appreciated - thanks again.
    Andy
  7. #7
    Jun 2014
    [QUOTE=Fortune7;2360190]Mike,
    Andy
    Your welcome Andy
    I have an 1100 s3, so I am glad that you got it going even with a bit of misinformation......
    The downside is that evey time you update you will have to make the changes again, not the end of the world though.
    mike sr
  8. #8
    ADMIN SET_Y_LIMIT is a better route if your ball screw is long enough. MDI auto-completion should show you all of that. Or ADMIN HELP does also.
