- Why can't I figure this out?
Working on the SL15.
I am trying to remove material from the inside of a part, which is going fine. But what I want to do is make a final clean up pass on the inside face and wall. On my manual lathe, this is what I would do.
I can't figure out how to get path pilot to allow me this.
Any help?
Don't take the picture too literal.
Re: Why can't I figure this out?
Profile instead of ID Turn!!
I still don't know what was going on. I was working with PP with the machine off and just the controller powered up. Started getting errors when trying to save edits that stated it couldn't be done with the machine powered off.
Rebooted, powered everything up, still had an issue.
Wrote down everything that I had already entered, deleted the file, rebooted with a full power up. Re-entered all of the info again....works fine.
- You may not post replies
- You may not edit your posts
Forum Rules
