PathPilot and NO run from here function
Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: PathPilot and NO run from here function
    Oct 2005
    Default PathPilot and NO run from here function
    Using the latest PP version I do not see a Run From Here function. DId I miss something ?? Running files in teh 300K - 500K line count not having a RFH function is a deal breaker.
    (;-) TP
    Nov 2005
    UK
    Default Re: PathPilot and NO run from here function
    Scroll to the line you want, right click mouse, set start line - is this not in the latest version??
    Jul 2017
    'Set Start Line' is the actual name of the context menu item.
    And newer versions of PathPilot even have that available in a 'hamburger menu' in the upper right which is touch screen friendly (since with a touchscreen you don't have "right mouse click").
    Oct 2005
    Sorry Guys but that is not a Run from Here function. Not even close. It is simply a set next line function. That won't cut it for a restart function.
    (;-) TP
    Jul 2017
    Please clarify the distinction in your mind between "run from here" and "set start line"
    I don't see any difference at all.
    Nov 2005
    UK
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    You need to clarify what you want? I've used 'set start line' more than a few times to run the program from a specific operation point, when I've either broken a tool, or need to adjust a cutting parameter and go back and do it again. What it doesn't do is start the spindle or the coolant...you have to do that yourself. Other wise, 'set start line' is **exactly** 'run from here'....
  7. #7
    Oct 2005
    Try useing it to restart on an arc (;-) . It also does not rspect teh modal values that should be in play and does not start teh spindle. It also does not do a safe return to position as it only goes in a straight line From XYZ back to teh restart point.. It should goto XY then down to z.
    Not my first rodeo fellows, (;-) TP
  8. #8
    Jul 2017
    Thanks - that's helpful. Perhaps they'll be able to add some of this.
    Most use cases I've seen are restarting at the last tool change - which usually has a lot of this already by its nature ('park where its safe to change a tool and then restart').
  9. #9
    Nov 2005
    UK
    Try useing it to restart on an arc (;-) . ) TP
    Good point - never tried that I've usually just gone back to a previous safe point between cuts, or the start of particular operation.
  10. #10
    Oct 2005
    You can get really close by rewriting some of teh G30 code to use it as a return and restart function. It can do everything needed EXCEPT do teh actual run from line at that point . It always reverts back to teh beginning of teh program. I cannot get it to restart from teh Run From Line. There is a glitch in PathPilot . I am trying to create a work around. So far Close but no cigar for RFH.
    (;-) TP
  11. #11
    Oct 2005
    IF this helps anyone here is a proceedure to do a RFH function in PathPilot.
    From Running Gcode
    STOP
    from MDI G30.1 M80
    Do what ever you need
    From MDI M81 G30
    In Gcode window select teh restart from line (left click)
    Then Right click and select Run From Line
    CycleStart to restart.
    This will restart in an arc as well. I am trying to roll it all into a 2 part function 1 gather all data 2 Restart . The problem so far is finding what teh Start From Line code is and can you apply teh line number to that function. As is it appears to be a mouse click function. I also modified teh G30 code to first move up to Zhome, THEN move in XY to teh restart position and then lower Z back to the restart position. I also can turn on teh spindle and coolant from code
    So it is possible to do a proper RUN FROM HERE in PathPilot so Tormach really needs to add this function to PathPilot (;-) But that is my opinion theirs may vary.
    (;-) TP
    (;-) TP
  12. #12
    Nov 2012
    I agree that a "run/continue from here" that walks through the modal state and applies all the right bits to continue would be valuable!
    (it doesn't need to start/stop motor/coolant/relays while pre-rolling; just apply the state it arrives at in the end)
    This may be tricky for cases where there are conditional breaks, reads from inputs (to wait for pallet ready,) and so forth.
    Most users probably don't do too much with those, and for those who do, it would be possible to remember what path the code took for each line in the past using a small amount of memory in the controller, because you only need to remember lines where you didn't just run the next line.
    Currently, I end up scrolling backwards until the previous tool change, and set that as start-line. Even a simple "find reverse" function or even "scroll to previous/next stop" in the Gcode window would help with that!
