Weird moves on the lathe ( please help solve this) (see pictures)
Results 1 to 3 of 3
Thread: Weird moves on the lathe ( please help solve this) (see pictures)
    Banned
    May 2008
    Default Weird moves on the lathe ( please help solve this) (see pictures)
    I will try to explain the best I can but this is really weird.
    I can only move 1 axis at a time no matter how I connect both stepper drivers.
    See pictures
    Normal connection
    Z+ and Z minus are working as they should
    No move on the X axis
    If I switch signal cable ( X signal on Z stepper driver and Z signal on X stepper driver)
    No move on the Z axis
    X axis become Z axis
    If I switch power cable going to stepper motor (signal cable in normal position x signal to X stepper driver --Z signal to Z axis driver)
    Z axis become X axis
    If I switch both, signal cable and power cable (from X to Z and Z to X)
    X axis move
    Attached Thumbnails Attached Thumbnails Weird moves on the lathe ( please help solve this) (see pictures)-signal-cable-reversed-1-jpg   Weird moves on the lathe ( please help solve this) (see pictures)-normal-connection-1-jpg   Weird moves on the lathe ( please help solve this) (see pictures)-signal-power-cable-reversed-1-jpg   Weird moves on the lathe ( please help solve this) (see pictures)-stepper-cable-reversed-1-jpg
    Member cncmakers001's Avatar
    Jul 2011
    China
    Default Re: Weird moves on the lathe ( please help solve this) (see pictures)
    Seems X axis stepper driver has problem.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Banned
    May 2008
    Thanks for the reply.
    But if you look at pic #3, X axis move
