Are you saying the controller trips when no probe is attached?
If so, then the connection or wiring is loose somewhere. It may be the connector on the mill, it may be the wiring harness inside the mill, or it may be the cable from the mill to the controller.
Make sure everything is tight and snug and there are no loose wires anywhere.
