Anybody is using the inputs on USB I/O board ( the one with the output relays)
Results 1 to 3 of 3
Thread: Anybody is using the inputs on USB I/O board ( the one with the output relays)
    May 2008
    Default Anybody is using the inputs on USB I/O board ( the one with the output relays)
    I have a digital part counter connected to one of the output relay of the USB I/O board.
    The counter has a relay on the output also and I would like the lathe to stop when input 1 is high or low.
    I also use the counter inside the program.
    Could somebody give me some help on using inputs and how do I program it in pathpilot.
    Thanks in advance.
    Jeff
    This is a picture of the counter I'm using
    Attached Thumbnails Attached Thumbnails Anybody is using the inputs on USB I/O board ( the one with the output relays)-s-l200-jpg
    Member kstrauss's Avatar
    Apr 2013
    Default Re: Anybody is using the inputs on USB I/O board ( the one with the output relays)
    There are examples in the USBIO manual (https://www.tormach.com/support/wpdm...all-0717a-web/). See page 5 for an example of using M66. You can check an input, wait until an input is high or low or wait until an input changes.
    Dec 2008
    Switzerland
    Quote Originally Posted by jeffrey001 View Post
    Did the response from kstrauss answer your question?
    Step
