- How to find a probe log file on Path Pilot
I am trying to get smartprobe.ngc working on my 1100 with Path Pilot 2.0. The G code for smartprobe stores the log file (probe-results.ngc) in the same directory as the path pilot .ini file. Can someone tell me how to find that file and or copy that file to a USB drive so I can get it into Rhino?
Re: How to find a probe log file on Path Pilot
Found the answer, Upgrade to PP2.16.
The logfile now appears on the home screen list of files under whatever name it was assigned in the g code file.
- You may not post replies
- You may not edit your posts
Forum Rules
