What is the combination of hardware and software you are using?
I was thinking of using the jog shuttle to do some manual milling moving a set small distance. I switched from jog mode to continuous and moved the speed slider right down. I expected that this would slow the feed rate right down but found to have little or no difference.
I am using PathPilot . Update v1.9.12 . Tormach PC. Tormach 770 mill
