Pathpilot install
Results 1 to 10 of 10
Thread: Pathpilot install
    Member popspipes's Avatar
    Jun 2014
    Default Pathpilot install
    I am thinking about a solid state drive and a newer computer, question is can Pathpilot be installed onto an empty drive from the PP usb stick?
    any insight appreciated
    thanks
    mike sr
    Dec 2008
    Switzerland
    Default Re: Pathpilot install
    Hi Mike
    PathPilot certainly can be installed on an empty drive.
    Step
    Jun 2014
    Thank you sir!
    I wasnt sure as it had to do with installing it over the 1.9 series, good to know as I am thinking about a spare computer setup for the mill and I would like to try one of those SSD drives.
    Quote Originally Posted by TurboStep View Post
    Hi Mike
    Step
    mike sr
    Member kstrauss's Avatar
    Apr 2013
    Many older Tormach supplied controllers used 3.5-inch drives while most SSDs are 2.5-inch. There are cheap (<$10) sheet metal brackets to adapt to the smaller drives. Just a heads up so that you don't get the drive and find that it can't be installed. Don't ask how I know! My 120GB SSD has worked great so far.
    Jun 2014
    good to know thanks
    I will most likely go to EPC and have it put together so that it works out of the box, then order the appropriate mesa card for it, would like one of the smaller ones but I need their input on that as far as problems etc..
    Quote Originally Posted by kstrauss View Post
    mike sr
    Mar 2013
    U.S.
    Hi Mike
    Step
    Does that apply to PP 2.x.x? I have the 2.0.0 on order but meanwhile my old HD bit the dust. I've ordered a new drive and PP 2.0.0 should be arriving with in the next week.
  7. #7
    Apr 2013
    Do you mean a 2.x.x upgrade file? For a virgin machine you have to install 2.0.0 from the USB drive and then install the desired upgrade. The upgrade files contain just a tiny fraction of everything comprising Linux, Linux apps and PathPilot.
  8. #8
    Mar 2013
    U.S.
    It will be with a new hard drive, probably won't even have an operating system on it. The PathPilot will be, when it arrives, 2.0.0. I want to install it on the new hard drive.
  9. #9
    Apr 2013
    To install on a virgin machine -- one with or without the hard drive formatted or an OS installed -- boot from the PP 2.0.0 USB stick and respond to a few prompts. It takes only a few minutes and should be painless..
  10. #10
    Mar 2013
    U.S.
    Thanks.. I'm a low tech guy in a high tech world. My VCR is still flashing 12:00
Pathpilot install
Pathpilot install
