Are user changes to PP required or is it completely plug-and-play?
Looking for a few beta testers. Send a PM with some details about your use case for beta testing.
I'll be watching this. I've wanted the possibility to trip some relays (cycle end / M01 lights, air blast etc) but couldn't justify the cost of the Tormach version.
M
Others may disagree but for me a completely plug-and-play solution would be vastly preferable; I really don't want to have to bother with editing and then, possibly, correcting my typing mistakes. Merely providing the same capability for a few dollars less for the board would not convince me to forego the joys of no installation problems and Tormach support. And I'm reasonably computer literate (my career was in software development). Obviously others will have different opinions. Providing additional capabilities/ better packaging/ whatever might convince me otherwise.
...which is one reason why my version is "completely plug-and-play". Although my PathPilot installations are far from standard I don't feel the need to add any additional changes unnecessarily.
I developed this board essentially as a test for a more complex exercise, so I'll be making a few for myself but I have no intentions (at the moment) of selling them. I'm not sure how Tormach would react. The price of the parts is significantly less than the price of the Tormach board but obviously the cost of building, testing and support must be added to each unit with a proportion of the total development costs (plus profit). We should also not forget the cost of the PathPilot integration which Tormach is providing. The production quantities are probably not very high.
I must say I like the LinuxCNC M62-M65 codes, and even more so the M66 codes, but there are other, faster (propagation delays) ways to use them - with small changes to the hal file.
Step
I think instead of asking potential customers "What are you willing to pay?" you should first ask "How many are interested?". I would imagine knowing the market size (demand) would be the first step to establishing weather or not there is a demand. Then once you know what the market size is you can work backwards and figure out what your selling price might be for the market size.
Then come back and ask who is willing to buy at your asking price and see if the demand is still there. After your beta testing is complete and any bugs worked out this product might be a good candidate for a kick starter.
Good comments by all. Thanks for your input. This is completely on the cheap. the board is a freely available board out of China for less than $10. We just developed firmware for it to make it work this way. There is about $25 dollars in material total needed to make this work. there are 2 drawbacks of this board however: 1- no USB isolation but a USB Isolator can be bought for $10. 2- there is no input isolation on this board so you will need to only use dry contacts or implement your own.
We are considering releasing the firmware in binary form, possibly on a donation basis. We have little interest in making a large profit but covering development time would be nice. We did consider selling kits in the past but have moved away from that idea.
Relay Board
USB Isolator
We would still like to beta test with a few people to insure a completely functional device. We wouldn't recommend this for a production environment, but consider it a great solution for the home shops.
I would love to turn a relay to M07. How different is that from the M62 or M1xx approach?
Update: I meant M7 -- I already have flood coolant on M8.
Looks like this project is a bust at least for now. The latest batch of boards from China have a different microcontroller than the original development board we wrote firmware for. The new boards have a Nuvoton N76E003 which I don't currently have a development toolchain or a programmer for. They saved a few cents with the mcu swap and killed this project in the process.
The code can easily be ported to an Arduino or ESP8266. This may become an open source project after all.
If you want to use the M64/M65/M66 codes with a microcontroller, I whipped up the following for Teensy 3.2 boards:
https://github.com/jwatte/teensy_tormach_usbio
You could then use that board to in turn drive a relay or whatever. Not as snazzy as all-in-one, but it solves the "arduino-like interface" problem.
https://amzn.to/2RzaNEd
Yeah, the main problem with that is that it requires re-applying after each update.
The Teensy firmware seems to integrate fine with the PathPilot, so I can put air blast on M64P0 and call it good. (I could even mod the firmware to do intermittent air blast on a timer.)
I wonder if there's a convenient hook to always turn it off at M30, though. Or if that requires modifications that need to be re-made each update?
I realize that the touch sense capability is Teensy specific but is there anything else Teensy specific in your example? That is, will similar code work to interface an Arduino board that uses the Atmega32U4 if I change the VID/PID in the 40-teensy.rules file? I'm anxious to try some ideas and I don't have a Teensy here to play with...
Anything I can forget to do manually, I will forget to do manually! It's even more likely to be forgotten if it only happens once a month.Tormach don't release a new version every day!
There's a #define you can change to do regular digitalRead() instead. Also, I think the 32u4/Leonardo has fewer I/Os so you may need to change the specific pins used. The MSG_PIN (pin with LED) may be a different pin, too? I haven't used the Arduinos in a long time, so I don't remember exactly.is there anything else Teensy specific in your example?
And, finally, do the Leonardos do SerialUSB instead of Serial for the USB serial port? You'd have ot update that, too.
And if your serial port needs a baud rate, Tormach uses 38400.
The basic loop and command/serial parsing should work fine. It's really not very complicated, once I figured out the bits it wanted.
I added a #define to make it work with a regular Uno instead (set ON_ARDUINO to 1) and you should be able to go from there!
