- PathPilot® v2.1.6 Now Available
In This Version-
Please be sure to read the release notes for a complete summary of all enhancements and bug fixes, the most important improvements are noted below.
Enhancements:
All
• Information on all available G-code modes is now available by hovering over the items in the G-Code Description window on the Settings tab.
• PathPilot now finds an available network adapter as the controller powers on, improving the out-of-box experience.
• File storage on the PathPilot controller's internal drive has been expanded resulting in a program storage increase of over 75 GB on most controllers.
• Warnings for zero-length tools (on a mill) or tools with the default tip orientation 9 (on a lathe) are now suppressed if a file of the same name is loaded.
• In Conversational threading, the Quick Reference drop-down now lists an option for SAE 5/16-18.
• When an axes' work offset value is changed, the Status tab now displays a message with the old and new values.
• We changed the label above the axes' Work Offset DRO fields to display the current work coordinate system as a reminder
Mill
• We added support for the Door Lock Switch Kit (PN 38283).
• When coordinate rotation is active, the text in the X-axis Work Offset DRO field and Y-axis Work Offset DRO field now displays in an italic font.
• After enabling an Enclosure Door Switch Kit (PN 35550), an LED displays on the Status tab.
• If air pressure is momentarily below the minimum requirement while using an Automatic Tool Changer (ATC), tool change reliability is now improved.
Fixed Issues:
All
• We fixed issues where:
o A G-code file with blank lines before the first % line sometimes didn't display the image or comment in a M00 or M01.
o G90.1 and G91.1 didn't display in the Status read-only DRO field.
o The View Options tab didn't expand correctly when the G-Code window was expanded.
For release notes and more information on this version as well as issue tracking and reporting visit the PathPilot Software Center.
- You may not post replies
- You may not edit your posts
Forum Rules
