- Probing routines
Probing routines
I use the probing routines almost for everything and it would be nice if it would select tool 99 and 20 ipm when going to the probing section, I wonder if anyone has modified the routine to accomodate these settings?
Just trying to eliminate another variable or two, maybe a bit less screw ups for an old guy??
- Probing routines
- You may not post replies
- You may not edit your posts
Forum Rules
