PathPilot® v2.1.4 Now Available
Results 1 to 6 of 6
Thread: PathPilot® v2.1.4 Now Available
    Member kstrauss's Avatar
    Apr 2013
    Default PathPilot® v2.1.4 Now Available
    In This Version-
    Please be sure to read the release notes for a complete summary of all enhancements and bug fixes, the most important improvements are noted below.
    Enhancements:
    All
    • On the File tab, added functionality to cut, copy, and paste files
    • During program execution, a time remaining clock was added based on the cycle's previous run time
    • Tools used by the current G-code program are now indicated in the Tool Table window — if a tool is used, its corresponding Tool column header becomes shaded
    • In the logfiles folder, there's now a log file with a history of G-code programs that have been run and their timings, called gcode_log.txt
    Fixed Issues:
    All
    • If the work offset was changed, the display in the Tool Path window didn't immediately redraw
    For release notes and more information on this version as well as issue tracking and reporting visit the PathPilot Software Center.
    Default Re: PathPilot® v2.1.4 Now Available
    Here's a link to the complete PDF release notes.
    https://www.tormach.com/support/wpdm...=1537373889607
    Jun 2018
    on my feet
    will the update wipe out my current offsets ?
    Member popspipes's Avatar
    Jun 2014
    Quote Originally Posted by metalmayhem View Post
    I installed V2.1.4, I did export the tool table from V2.1.3 and it showed up in V2.1.4 without doing anything but installing the update.
    I ran one of my programs several times and it ran without a hitch..........
    mike sr
    Member mountaindew's Avatar
    Nov 2007
    earth
    ….Tools used by the current G-code program are now indicated in the Tool Table window — if a tool is used, its corresponding Tool column header becomes shaded
    Simple but very nice addition! I love it.
    Apr 2013
    Definitely a good change! It would be even better if one could set tool table entries as undefined and flag their usage in red. I've set all unused entries to 11.1111 which solves many problems.
