Jogging error
Results 1 to 4 of 4
Thread: Jogging error
    Member popspipes's Avatar
    Jun 2014
    Default Jogging error
    I have a new error, never had it before, starting a program it will give a "probe jogging error during an MDI move" and shuts the program down. When I reset the program and restart it the same error happens. A reset and reload of the program fixed it for one run then it reappeared.
    I did install a renishaw MI8 interface a few months back, I am wondering if that is causing the error??
    any insight appreciated....... new one on me......
    mike sr
    Jun 2014
    Default Re: Jogging error
    The problem seems to be heat related, opened the electrical cabinet door for a few minutes and the problem went away, the program started fine.
    mike sr
    Member kstrauss's Avatar
    Apr 2013
    I believe the error is the result of a state change in the signal from the probe while moving. I suppose that could be a temperature related issue and the MI8 or perhaps vibrations are causing the contacts on your Renishaw probe to open for a fraction of a second.
    Jun 2014
    Quote Originally Posted by kstrauss View Post
    It hasnt done it since, the probe isnt connected to the interface, we will just have to see how it plays out.
    thanks for the input
    mike sr
Jogging error
Jogging error
