- Dual monitors while in pathpilot
Some assistance from the linux experts would be appreciated.
I currently dual boot my workshop computer in either windows or pathpilot in sim mode.When I boot it to pathpilot it goes straight to the desktop and both monitors are working but as soon as I start the pathpilot interface it shuts the second monitor down.I can restart it manually but is there any way to modify a configuration file to stop pathpilot turning the monitor off.
Re: Dual monitors while in pathpilot
Thanks,will look into that.
Would still like to know a little more about how everything works in linux / pathpilot though.More research needed.
Yes I have setup PP to boot into the desktop and created a launcher but when I launch PP it does take over the desktop and does shut the other monitor down so I must have missed something somewhere along the way.
I have made a keyboard shortcut to get back to the desktop and it is easy enough to manually restart the second monitor but I was treating this as a bit of a learning exercise.
Thanks rdsi,my launcher was in fact a shortcut to the operator login and once I used your command things worked as you said it would.
- You may not post replies
- You may not edit your posts
Forum Rules
