- PP 2.12 ADMIN TOUCHSCREEN
In pathpilot 2.1.1 and 2.1.2 it works ADMIN TOUCHSCREEN ?
It does not work for me, in PP 2.0.4 it worked.
Roberto
Re: PP 2.12 ADMIN TOUCHSCREEN
I just tried it on 2.1.3 and it is working for me. After upgrading to 2.1.3 and it still isn't working, check your USB cable from the monitor to the computer.
Tomorrow I try to update to 2.1.3.
The cable is OK before going to the 2.1.1 I had done with 2.0.4 and it worked.
Even with 2.1.3 it does not work.
There is some other system to calibrate the monitor (LG 17MB15T Touch Monitor 17 '')
- You may not post replies
- You may not edit your posts
Forum Rules
