- Need Help!- Coversational drilling error
Trying to do some programming in conversational for my Rapidturn. I set up the drill bit as the number 5 tool with the description; "Drill CoHSS Dia:.157". As soon as I entered the tool number into the conversational drill panel, I got the error; “Could not convert string to floatâ€. I tried less detail by just using the word "Drill" in the description and I also tried to add more detail by adding the "loc:" parameter.
Has anyone run into this before and how did you fix it?
- You may not post replies
- You may not edit your posts
Forum Rules
