Originally Posted by
syscore
How exactly are you setting up G54?
In PathPilot, you move the table/head to where you want zero to be and then press the Zero-X and/or Zero-Y and/or Zero-Z buttons, depending on which axis/axes you are zeroing. Is that what you mean by "setting up G54"?
Can you try this...
1. Put stock in vice.
2. Using Haimer, find left edge of stock.
3. Press Zero-X. (X should now read 0.0000 in PathPilot)
4. Raise head and jog around some.
5. Type G0X0 in MDI
6. X display should read 0.0000 and the tip should be right over the left edge.
Repeat this for Y.
