Originally Posted by
rdsi
Another thing to keep in mind when networking multiple machines are the NetBIOS and hostname names. By default Tormach uses tormachpcnc for both & in standalone situations this is fine.
However, if you have multiple machines like both the mill & lathe, or some other combination, each machine needs to have a unique name. Even if you're running PP in a VM it will need a a unique name too. Otherwise you will have a problem if any two instances of PP are running with the default tormachpcnc and you have them networked together.
So I've been using the following for my machines & VM's: PPMILL, PPLATHE, PPDEV, PPVBOX1, etc. Typically I use all uppercase for the NetBIOS name & lowercase for the hostname. Yes, sometimes I have them all turned on.
