Solved Path Pilot v2.0 Network (Samba) Share Not Accessible - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: Path Pilot v2.0 Network (Samba) Share Not Accessible
  1. #25
    Member Doug Darby's Avatar
    Nov 2011
    Default Re: Path Pilot v2.0 Network (Samba) Share Not Accessible
    Glad it worked. I just setup a new internet service and it asked me and luckily I had it in my notes from the first time...
  2. #26
    Member mountaindew's Avatar
    Nov 2007
    earth
    Anyone have a trick for setting up a network share in windows 10 with a networked PP controller to move g-code?
    I see everything on my network but the mill. I can see the mill is connected to router and working but no way to connect to any windows 10 system.
    Any pointers would be great.
  3. #27
    Jul 2017
    What version of PathPilot are you running?
  4. #28
    Nov 2007
    earth
    Quote Originally Posted by old-cnc-geek View Post
    Current, I keep it updated. I'm thinking its windows 10 problem and some past windows update disabled some network functions. I have no workgroup anymore as mentioned here, or its hidden.
  5. #29
    May 2015
    I would check your SMB settings in Windows 10. If you go to the control panel > Program and Features. Select the turn windows features on and off Path Pilot v2.0 Network (Samba) Share Not Accessible-control1-pngand then make sure that the SMB functions are checked. Path Pilot v2.0 Network (Samba) Share Not Accessible-smb1-png.
    I have seen this effect network connections between Windows 10 and other SMB connections (Windows Server 2003 and 2008,etc).
    Chris
    Attached Thumbnails Attached Thumbnails Path Pilot v2.0 Network (Samba) Share Not Accessible-control1-png   Path Pilot v2.0 Network (Samba) Share Not Accessible-smb1-png
