- Problem- Torchmate CAD Accumove patch
Has anyone been able to install the add-on driver / .gm post processor on TM CAD V5.0 rev12? The instructions show "install driver" in machine settings. But V5 doesn't have the button. I've tried to rename the driver= in the config settings file to match existing gcode53. But that wouldn't go anywhere but error with the gcode53 driver.
Re: Torchmate CAD Accumove patch
The patch will not work with V5.0 via TM Tech. I upgraded to V9 which patch is preinstalled.
- You may not post replies
- You may not edit your posts
Forum Rules
