- Help plz ,my Accumove 3 THC can't start the job
Hey ! i'm new here
I have a Torchmate accumove 3
When i run a job, the torch touch the material then go up ... and keep doing that without cutting
I'm using Powermax 45
Any one have an idea ?
Re: Help plz ,my Accumove 3 THC can't start the job
If the torch makes contact with the plate and continues to slowly raise up, this means it is still detecting ohmic and trying to lift off the plate to break the circuit. Could be debri in the shield cap or you may have the shield cap screwed on too tightly, may try unscrewing the shield cap slightly to increase the clearance between the inner nozzle and shield cap.
- You may not post replies
- You may not edit your posts
Forum Rules
