Hi Bob
love the build its promted me into building a small 4x4 one of my own at last, after many years of thinking about it. I have read your thread and many others many times and taken in most of the comments, now I have finaly drawn one up taking ideas from all over the place I like the idea of a light aluminium beam with a 25mm hiwin rail with a single wide carrage, over a 60x60mm box frame with a 75mm cold rolled top track, with dual motors on the "X" axis (if I can work it out) the electronics seem to be a bit of a mystery to me at the moment, no doubt it will become clearer, eventualy, as will Mach3, with a MP1000C-THC if I can get one shipped to here, I just dont quite understand what else I will need at the moment, but as with every thing else bu the time I need them I possibly will.
I have a few questions I would like to ask you
what DP are the gear racks you used? and the diameter of the pinion gear?
Im going to use 54t and a 16t xl belt drive with a 70t belt, that gives me a reduction of 3.375:1 what did you use? I have drawn all the motor mounts so they can be spring loaded against the rack they only have at the extreme ends of movement 3/8in in the pinion gear to allow for any "Tight" spots or backlash
there are some 1.86Nm - 263oz or some 3Nm - 425oz Stepper motors on ebay uk both size 23 which would be best? there is less than $10 difference in price
any comments will be apreciated I need all the help I can get, but please dont flame me too much we all started somewhere
this was last years project
as was this my hydraulic conversion to a JD2 bender
See Im quite good at somethings
Steve
