Problem Walter HSM500 mini power break down - Need Help
Results 1 to 4 of 4
Thread: Walter HSM500 mini power break down - Need Help
    May 2013
    Singapore
    Default Walter HSM500 mini power break down - Need Help
    Hello,
    Walter HSM500, 1999 build broke down with A-Axis error. Unable to recover the machine to access the A-Axis motor. Alarm C2/17 is shown on the Drive, means trouble with motor encoder or cable. Need Help to bypass A-Axis, so that other Axis can be moved to safe position to check the A-Axis motor and cable.
    Machine is equipped with Windows NT / ANDRON CNC Software / Indramat motors / Rexroth Drives.
    Referring Bosch Rexroth manuals, one of the possible ways seems to be changing E2PROM settings to remove definition of A-Axis in the CNC settings.
    I am able to access E2PROM data from windows using the shortcut START -> PROGRAMS -> HSM500 Power -> E2 PROM DATA.
    I am unable to access all E2 PROM settings through the above shortcut, only basic settings can be seen. Believe there is a special way or password to access advanced setting in the E2 PROM data. Need to help to access Machine builder setting in the E2 PROM data.
    Thank you for your valuable support.
    Jan 2007
    canada
    I can help.
    What is your email?
    Chris
    UOTE=mahesh17179;2393786]Hello,
    Thank you for your valuable support.[/QUOTE]
    May 2013
    Singapore
    Default Re: Walter HSM500 mini power break down - Need Help
    Hi Chris,
    Thanks for the support, My email is mahesh17179@gmail.com
    Quote Originally Posted by cb1 View Post
    I can help.
    What is your email?
    Chris
    [/QUOTE]
    May 2013
    Singapore
    Hi Chris,
    We are still stuck with the problem on the machine. Your support would be very useful. My email is mahesh17179@gmail.com
    Please help.
