Need Help! Surfacing onsrud router table
Results 1 to 2 of 2
Thread: Surfacing onsrud router table
    Activation process rfjr88's Avatar
    Jan 2019
    Default Surfacing onsrud router table
    I have no idea how to surface my osrud table. I'm use to running multicam routers. Which is pretty easy to surface. I have very little training with this osrud table.
    I have no idea where to start, So any help would be greatly appreciated!!!
    How do I set the height on my MDF?
    C.R. Onsrud M series model # 4100M12
    Using a OSAI controller
    Vcarve Pro
    Thank you,
    Member routalot's Avatar
    Dec 2003
    Default Re: Surfacing onsrud router table
    I just found this post and sympathise with the problem.The best solution I found was to use the pocket feature and to create a vector,just a touch larger than the spoilboard, to indicate the boundary of the cut.Then just create a pocketing routine to the shape and desired depth.It worked for me.
