Cutting 2”x2” squares 1/8” thick aluminum
Results 1 to 3 of 3
Thread: Cutting 2”x2” squares 1/8” thick aluminum
    May 2020
    Default Cutting 2”x2” squares 1/8” thick aluminum
    Anyone familiar with cutting 1/8” aluminum. I’m trying to get some different set up options. Right now I run around 300-1000 placards at a time and then have about 20-25 hrs To clean up all the parts. I’m looking for a setup that would have a next to mirror finish on all edges and no burr and ideas would help.
    Attached Thumbnails Attached Thumbnails Cutting 2”x2” squares 1/8” thick aluminum-ded82e77-a7ef-40a3-86ae-c0cff4aed72a-jpg   Cutting 2”x2” squares 1/8” thick aluminum-6584f044-b95b-411e-b856-59ba8be218a7-jpg
    Attached Files Attached Files
    May 2020
    Default Re: Cutting 2”x2” squares 1/8” thick aluminum
    I’m currently using a multi cam 1000 flatbed vac router. Programming through enroute.
    Dec 2013
    My best suggestion is a sharp 3 flute, aluminum cutting, carbide end mill. I personally like the Onsrud cutters, but there are many others. Use heavy spray mist, with good airflow to remove the chips. Or use flood coolant. Make a roughing pass, leaving about 0.005''/side for a cleanup pass. Adjust your feed and speed for at least 0.001'' feed per tooth on the finish pass. The edges will look polished when finished.
    Jim Dawson
    Sandy, Oregon, USA
