Greeting y'all. I have bought high density foam for carving on my CNC in the past, but I cannot find the supplier that I bought from, any suggestions? Thanks in advance. JimSimilar Threads: High Density Urethane Foam Tooling/Sign Board - 12lb and 30lb - 100+ Cubic Feet Avail High Density Urethane foam Where to buy high density foam? High Density Urethane Foam (A.K.A. Butter-board)
Try these guys: McCausey Specialty Products: Scaffold Boards, LVL, GluLam, Plywood in Roseville, Michigan
Thank you I'll check them out.
Originally Posted by louieatienza Try these guys: McCausey Specialty Products: Scaffold Boards, LVL, GluLam, Plywood in Roseville, Michigan I know this is an old post but thought that I would take a shot. What density do you use?
Originally Posted by dvaskie127 I know this is an old post but thought that I would take a shot. What density do you use? Can't remember, but call them and speak to a rep, they were more than helpful with me.
View Tag Cloud
Forum Rules
