- Laser cutter software RDworks v8 tutorial 03 How to Change the Layer Color
Hi this is ken from Thunderlaser. Today we will learn how to change the layer color.
We can see there is only one layer in this project. If we want to change some objects into other layers. How can we do? First select the circle then click blue color on the bottom of the software. Now the circle turns to blue color. Let’s select the rectangular and click red color. We can see a red layer is added.
Then select another object and click green color. Now we have 4 different layers. There’re totally 20 different colors in the laser cutter software. But if we want to add even more layers, we can use CorelDraw or other software directly.
That’s all for today. See you.http://www.thunderlaser.com/video/ho...yer-color.html
Re: Laser cutter software RDworks v8 tutorial 03 How to Change the Layer Color
- You may not post replies
- You may not edit your posts
Forum Rules
