Originally Posted by
cbix
I am having difficulty with a TechnoCNC HD Series Router. It has the NK-105 G2 handheld controller.
I have reset the Manufacturers Parameters to default. When I turn the machine on, it asks to home. When I press O.K. the machine travels up to the limit switch for the Z axis, then it does the same for the X and Y axes. At this point, it seems like things are going as they should.
Unfortunately, at that point I get the following message.
"Limit Exit Manually"
When attempting to move in the Z direction, it will not move down at all. No motor sound or other noise. It does, however, move up, past the limit switch, until the screws at the top of the spindle contact the metal of the frame. I am quite sure that this is not supposed to happen. I am pretty confident that if I were to continue, the motors would continue to try to push the spindle up, even though there is no room left to move. I am surprised that this is even possible.
The is no getting the machine to move from this position in any direction. Restarting the machine does not help, as the machine is still at the top of the Z axis, and will only move up.
The only solution I found was to go into the Manufacturer settings and change the Z axis from positive to negative. Upon restart, I can then move the spindle down. Unfortunately, when I attempt to home now, the spindle begins moving down, apparently looking for the limit switch, and it is clear that it would drive the milling bit through the top of the table if allowed to continue.
Not quite sure what to do. Any suggestions would be helpful.
