Can anyone help me identify this Isel router
Results 1 to 8 of 8
Thread: Can anyone help me identify this Isel router
    Default Can anyone help me identify this Isel router
    I’d like to try to find the model and any information about her thank you!
    Attached Thumbnails Attached Thumbnails Can anyone help me identify this Isel router-ebfbc14a-cf07-4e8f-a0e2-ee9886ab4ee3-jpg   Can anyone help me identify this Isel router-99bc6ffb-4595-4d6b-8c79-a7344019a860-jpg   Can anyone help me identify this Isel router-9ed587a1-c36c-4912-8b49-40b611f2e302-jpg
    Member ericscottf's Avatar
    Sep 2012
    Default Re: Can anyone help me identify this Isel router
    Eric,
    This is a gantry 027 or 130 or similar, the number varies based on the working size of the machine.
    Were you able to get a hold of the pc/control card?
    Regards,
    Eric
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
    Quote Originally Posted by ericscottf View Post
    Eric,
    Regards,
    Eric
    I was not im looking at getting one from armor cnc
    Eric,
    Regards,
    Eric
    Also the entire base measures a hair under 5’x6’ so I’m guessing maybe it’s the 130?
    Apr 2018
    I was gifted a similar machine but without the PC Card. I decided to fit new steppers and UCCNC control after seeing the price to replace the card. I still have the servo motors, wiring harness and drivers but didn't find a control solution within my budget at the time. There were solutions to the +-10v analog control without the original PC but I didn't have the confidence to spend and try them out. Also I didn't know for sure if all my drivers were still in working order anyways. Hope you find what you need!
    Cheers from British Columbia
    Aug 2005
    Wasn't this a forerunner to the Techno-Isel machines? I believe there are others out there that may still offer support. Good luck in your search.
  7. #7
    Quote Originally Posted by Gizmocnc View Post
    Hello GizmoCNC
    Would you be interested in parting with any motor and cable sets from the old set. I'm looking for Electrocraft E 242 or E243 servos.
    If so you can PM me.
    ShopWorks07
  8. #8
    Sep 2012
    Quote Originally Posted by ShopWorks07 View Post
    Hello GizmoCNC
    ShopWorks07
    Shopworks07,
    We have those motors if you can't find them elsewhere. Let me know.
    Also,fyi,242 and 243 are not necessarily interchangeable, be careful with what you do, let me know if you need any help identifying which you should be using where.
    Regards
    Eric
