- Techno/ISEL questions - coupler/ hand wheel / Z axis spring
Activation process
1. Is there a reason the hand wheels are constructed around a ceramic sandwich magnets?
2. The stepper couplers are the X rubber insert type. Considering replacing with the spiral variety. One had to be cut off after the small bolt stripped
Thoughts, suggestions ???
3. The Z axis is spring loaded which to me would make sense were it springing up but to me it appears to spring down toward the bed. Am I missing something?
Has something been rearranged before I acquired the machine? The way I see it, its appears to make lifting a heavy spindle more difficult rather than easier.
Again, thanks to all and apologies for the newbie intrusions . . . .
Activation process
Re: Techno/ISEL questions - coupler/ hand wheel / Z axis spring
Re: spring loaded Z
Just for reference, the Z axis ball screw has a spring loaded dust cover.
- You may not post replies
- You may not edit your posts
Forum Rules
