ISEL stepper question
Results 1 to 2 of 2
Thread: ISEL stepper question
    Activation process cncneon's Avatar
    Aug 2018
    Default ISEL stepper question
    Still in the evaluation stage trying to figure out if I can get what I have working and the best way to go about it.
    Once you have the housing off the steppers you have 10 wire coming out of mtr + a ground.
    There are 8 wires that pair up to 4 pins in the connector. Does this indicate a 5 phase stepper?
    Would I be better off just replacing these with a NEMA 34 midrange torque mtr?
    Thanks for any help
    cncneon
    Dec 2017
    Default Re: ISEL stepper question
    Just you need these 8 wires that you mention.
    in each pair dont use the white color wire and use another wire in that pair.
    then you will have stepper with only 4 wires and you can connect it regularly.
